Broche VFD Huanyang : Conseils pour mise en service SVP
+22
rogerj
perryd
El Poncho
para005
usual 57
Cyrille6901
Goodpapounet
gentipierrot67
Daniel 24
athanase
beni
remim
michel.be
Le Canayien
candidolf
Hagar
26 participants
Page 3 sur 10
Page 3 sur 10 • 1, 2, 3, 4, 5, 6, 7, 8, 9, 10
Re: Broche VFD Huanyang : Conseils pour mise en service SVP
Bon et bien, le câble de connexion est démonté et vérifier. Tout est ok, pas de court circuit.
Mais j'ai constater ceci sur les quatres pinouches de la broche.
1 et 4 = pas connectés ensemble
1 et 2 = connectés ensemble
1 et 3 = " "
2 et 3 = " "
2 et 4 = pas connectés ensemble
3 et 4 = " " "
Ça vous semblent normale ?
Voici le message que j'ai reçu du vendeur chinois , je n'ai pas encore tout compris, parce que en anglais.
Mais ayant appliquer à la lettre les instruction de Lio, je crois que les paramètres sont bons.
Dear friend
you should change the setting before you start it;
Regarding the wire connection, please connect "R" and "T" (at the inverter) to the shingle phase power supply (actraully, connect "R" and "S" or "S" and "T" both are ok.) If you use it as three phase input, then please connect the three phase power supply to "R, S T". "U, V, W " connect to the motor . If you use this VFD for this spindle motor 0-400HZ , Please set the parameters of the VFD as our following suggestion step by step, and don't change the sequence:Step 1: Set PD005 =400Step 2: Set PD004 =400Step 3: Set PD003 =400Step 4: Set PD072 =400PD144=3000As the orginal factory value setting is for a normal 50HZmotor, so please change the the above parameters according to your motor. If there have any other questions please feel free to contact with us.
Anyway,you'd better get a skilled worker to help you.
if it's till no good working,pls trake a video to us.we will teach you how to change the setting .
I also replied to your e-mail address; the video pls load in the website:www.photobucket.com
pls don't worry.My friend.
Best regards
jean
1 et 3 = " "
2 et 3 = " "
3 et 4 = " " "
Dear friend
Best regards
jean
Le Canayien- acharné du forum
Ah ! ça aurait été trop beau que ça marche du premier coup
Je ne pourrais pas t'aider pour le vario, le mien est différent, mais je peux te traduire ce qu'il raconte si besoin ?
Pour les fraises, il me semble deviner 3 fraises à denture diamant, 3 hélicoïdales standard, 2 fraises de mouliste (les sphériques) .. et 3 que je ne vois pas assez pour les identifier (à 12h, 13h et 22h) ... il y a de quoi débuter ... quand la broche tournera
Slu David !
Oui, j'aimerais bien que tu traduise le texte de Jean. Je crois que c'est pas sa langue maternel l'anglais. En tout cas moi, j'ai de la difficulté à le comprendre.
Pour la photo des fraises, je comprend que tu as de la difficulté à identifier. Elle a souffert de la réduction à 800. Je vais retourner une partie de la photo dans un autre format.
Pour celle qui est à 22 heure, c'est une fraise pour débavurer un perçage dans une flange mince en métal. Sa caractéristique est de pouvoir faire les deux cotés, sur le dessus, et sur le dessous l'un après l'autre. Pour le dessus c'est une fraise ordinaire qui fait un petit chanfrein. Pour le dessous, la cnc amène la fraise sous la flange en passant dans le trou. Ensuite la cnc fais un mouvement circulaire expansé, puis remonte pour créer un petit chanfrein.
Voila ce que je comprends.
Pas sur que ça t'aide beaucoup pour dépanner.
je n'ai par contre pas vu le PD072 dans les infos de lio.
le PD144 sert à avoir l'affichage correct de la vitesse de rotation du moteur (c'est sa vitesse de rotation à 50Hz)
Cher ami
vous devez modifier le réglage avant de la démarrer;
En ce qui concerne le câblage: Connectez l'alimentation monophasée aux bornes R et T sur le variateur. (en fait, connecter R et S ou S et T sont également valables)
Si vous utilisez une alimentation en triphasé (NDTR: ça ne te concerne pas) connectez les 3 phases sur R S et T.
Si vous utilisez cette VFD pour un moteur 0-400 Hz, réglez les paramètres de la VFD avec les valeurs suggérées en suivant pas à pas, et dans le même ordre la séquence suivante.
Etape 1: Réglez PD005 = 400
Etape 2: Réglez PD004 =400
Etape 3: Réglez PD003 =400
Etape 4: Réglez PD072 =400
Etape 5: Réglez PD144=3000
Etant donné que les réglages constructeur sont fait pour un moteur normal 50 Hz, il est donc nécessaire de modifier les paramètres ci-dessus en accord avec votre type de moteur.
Si vous avez d'autres questions, s'il vous plaît n'hésitez pas à nous contacter.
Quoi qu'il en soit, il serait préférable de faire appel à une personne qualifiée pour vous aider.
Si ça ne fonctionne toujours pas, envoyez nous une vidéo (???) nous vous expliquerons comment modifier les réglages.
Je vous ai également répondu sur votre adresse mail. SVP, uploadez votre vidéo sur www.photobucket.com
ne vous inquiétez pas mon ami.
Jean
Merci David pour la traduction !
Je vais remonter tous les branchements et faire le changement du PD 072 de 50 par défaut à 400.
Si ça ne fonctionne pas, je vais changer l'accélération à 2 seconde au lieu de 1.1 sur le paramètre PD014, que le vendeur à ignorer.
Je vous tient au courant, merci.
Ben non, ça ne marche toujours pas, malgré les deux changements.
Je vais essayer de connecter l'alimentation sur R T au lieu de R S.
En passant il faut attendre combien de temps pour que les condensateurs se vident avant de se mettre les doigts dans la série de visses ?
Ça ne donne rien non plus le changement RT et même ST.
Et bien je vais attendre une suggestion de vous tous.
En attendant je vais lire le manuel au complet une deuxième fois, peu être que…
Merci à tous !
Merci à tous !
Tu pourrais tenter de faire ce que demande Jean ; fait défiler et film les paramètres du vario, met en marche et film aussi ce qui se passe et envoie lui la vidéo. Il comprendra peut être mieux que l'Anglais.
Il y a peu être des réglages de base qui ne correspondent pas à cause du 110V ; A puissance égale l'intensité moteur est 2x plus élevée qu'en 220V ...
Oui tu as raison, je vais devoir m'y résoudre. Mais avant je veut essayer de trouver la raison des chiffres qui clignotent ASR 1, suivi d'un 164.4 qui monte à 165.1 et descend à 164.1
Ok, je vient de trouver dans les procédures de Lio, que ASR est la version du logiciel du variateur. Mais après cela, on est supposé voir quatre zéros qui clignotent et non pas 164.4
Peu tu m'expliquer cette phrase "A puissance égale l'intensité moteur est 2x plus élevée qu'en 220V …" Moi pas comprendre messié.
En monophasé la puissance(P) est égale à l'intensité(I) x la tension (V)
P en Watts, I en Ampères, U en Volts
P = U.I soit I = P/U
Pour 1500 W en 220V -> I = 1500/220 = 6.8 Ampères
Pour 1500 W en 110V -> I = 1500/110 = 13.6... Ampères
En triphasé, P = U.I.√3.cos(φ) -> I = P/U.√3.cos(φ)
je ne connais pas le cos(φ) de ta broche, pour la mienne il est de 0.7 (voir sur la plaque moteur)
en 110V tri pour une broche 1500 W -> I = 1500/(110x1.732x0.7) = 11.2 A
en 220V tri pour une broche 1500 W -> I = 1500/(220x1.732x0.7) = 5.6 A
en 380V tri pour une broche 1500 W -> I = 1500/(380x1.732x0.7) = 3.2 A
(les valeurs sont arrondies)
Merci pour cet explication détaillé.
Je vais la relire une dizaine de fois, et je devrais comprendre… une vraie flèche
Je vais enlever la fusible de 10 W, que j'avais monter dans la ligne d'alimentation sous les conseils de Lio.
Merci, et bonne nuit. Il doit être deux heure du matin chez vous ?
10 A plutot
oui, 1h30
PS: c'est pas le fusible qui fait merder, mais effectivement il est trop petit si la broche tire le max de puissance
bonne nuit
oui, 1h30
bonne nuit
Je ne connais pas ce message...
Tu peux compter sur Jean, j'ai déjà eu affaire à lui. David a raison, envoies-lui la vidéo, il va trouver une solution à ton problème...
Bon, si ça peut servir, voilà ce qu'il avait envoyé à un ami qui avait aussi le message "dl" :
Mais à ta place, j'attendrais d'abord sa réponse avant d'essayer ça... Ce sont des paramètres qui ne figurent pas dans le manuel, du coup on ne peut pas vraiment savoir à quoi ça correspond...
Lio
Please try to do as following:
Please set
PD200=65535
PD202=04
PD212=03632
Then turn off the power supply, and then turn it on again, after that, set the parameters again:
PD005=400
PD003=400
PD004=400
PD014=20
PD072=400
After this operation, please check whether the inverter still have "dl", and whether the spindle motor could run.
Lio
Totem- complétement accro
Totem a écrit:Salut,
Lio
Slu Lio !
Ce message ne m'était pas adressé à moi directement. C'était dans les instructions que tu donnais à Hagar, au début de ce post.
Voici le texte: Un fusible, ça il en faut un par contre. 16a ça passerait, 20 c'est vraiment limite... Si tu peux en mettre un de 10 juste pour le vario, c'est parfait! ça ne devrait pas te ruiner Wink
Si tu ne l'a pas pour les essais, ce n'est pas grave du tout…
Je vous ai dit que je lisais tout ce que vous "postiez" à propos des cnc.
Vous avez tout les deux raison, quand je vais reprendre la cession de test elle seras filmée et envoyer à Jean.
Merci et bonne après midi !
Euh, je me suis mal exprimé. Ce message-là, je le connais puisque c'est moi qui l'ai écrit
Je parlais du message d'erreur 164.4, je n'ai jamais vu cela.
Lio
Lio
Slu Lio !
Je ne suis pas sur que ce soit un message d'erreur.
J'ai l'impression qu'il affichai une lecture quel conque, parce que il y avait une variation.
Étrange...
Quelles diodes au dessus de l'écran étaient allumées à ce moment là ?
Désolé mais je ne me souvient plus.
Je sais que il y en avait qui clignotaient, et d'autre fixes. Mais en regardant dans le manuel, je n'ai pas retrouver ce patron de diode.
Maintenant il n'apparait plus, après avoir fait un deuxième "reset" et rentrer de nouveau tout les PD000.
Salut à tous, et je souhaite une bonne 2014 aux amis d'outre mer!
Une bonne nouvelle pour la broche… elle fonctionne parfaitement.
Après de nombreux échanges vidéos avec Jean (le vendeur chinois), le problème à été trouvé.
La mise à la terre sur cette broche, est à la position 4. Je l'avais monter en position 1, comme sur le diagramme si dessous.
Merci pour l'aide apportée!
Salut michel,
Ouf ça marche.
Le schéma que tu montre ... c'est celui de ma broche ... tu a mélangé, ou ils t'avaient fourni le même schéma ?
Ouf ça marche.
Slu David!
J'ai suivi ce schéma pensant que c'était un standard pour les broches. Il y avait aucune instruction pour la broche dans l'envoie de Jean.
Je lui ai demander si c'étais un oubli de sa part, mais il semble ignorer ma question. Il répond a toutes les questions, sauf celle là.
Alors, maintenant c'est le temps d'assembler la machine.
J'ai l'intention de faire venir ces pinces.
http://www.aliexpress.com/item/Free-shipping-Full-sets-ER11-1-7mm-13pcs-collet-beating-0-1mm-precision-spring-collet-for/783592617.html?tracelog=back_to_detail_b
Et ce bidule pour contrôler le variateur de fréquences par l'ordi.
Et ça pour refroidir la broche.
http://syscooling.en.ec21.com/offer_detail/Sell_CPU_cooling_kit--3627703.html?gubun=S
Si je me gour, ne vous gêner pas pour me suggérer d'autres idées.
Merci!
Merci!
Je pense que ce n'est pas utile de prendre tout un kit de refroidissement de PC, il te faut juste une pompe (aquarium) et du tuyau plastique ; pas de ventilo ni de radiateur, un simple bidon de 10L d'eau doit suffire largement, (le mini réservoir du kit est bien trop petit)
A ce moment la, où tu le met le réservoir de 10 litres?
Le Canayien a écrit:A ce moment la, où tu le met le réservoir de 10 litres?
salut,
Un simple bidon posé au sol, il est également important que la poussière ne rentre pas dedans.
Slu!
Il va falloir que j'achète une autre pompe. Parce que celle que j'ai est bonne pour un aquarium, mais elle n'est pas capable de monter la colonne d'eau du sol jusqu'au sommet de la machine.
pour l'hiver, vous utilisez un liquide de refroidissement antigel type radiateur de voiture ou autre ?
michel be
michel be
michel.be- complétement accro
» Conseils pour remplacement broche Sorotec basic line
» Broche VFD Huanyang en panne
» mise en route d un variateur hy plus broche 1.5
» Branchement Moteur de Broche VFD Huanyang
» Arrêt du fraisage d'une pièce après la mise en route de la broche dans Mach3 - Pourquoi ?
Page 3 sur 10
