Palpage XYZ
dume2309- je prends du galon
auto centre
voici le script que j'utilise pour ce auto centre du X et Y.....
PROBE X Y (AUTO CENTRE)
Rem VBScript To center probe inside a pipe
If GetOemLed (825) <> 0 Then 'Check to see if the probe is already grounded or faulty
Code "(Probe plate is grounded, check connection and try again)"
Else
FeedCurrent = GetOemDRO(818) 'Get the current settings
XCurrent = GetDro(0)
YCurrent = GetDro(1)
Code "G4 P1" 'Pause 1 second to give time to position probe plate
Code "F12" 'slow feed rate to 4 ipm
Rem Probe left
XNew = Xcurrent - 3 'probe 3 inches to left
Code "G31 X" &XNew
While IsMoving() 'wait for the move to finish
Wend
XPos1 = GetVar(2000) 'get the probe touch location
Code "G0 X" &XCurrent 'rapid move back to start point
Rem Probe right
XNew = XCurrent + 3 'probe 3 inches to right
Code "G31 X" &XNew
While IsMoving()
Wend
XPos2 = GetVar(2000)
XCenter = (XPos1 + XPos2) / 2 'center is midway between XPos1 and XPos2
Code "G0 X" &XCenter 'rapid move to the x center location
Rem Probe up
YNew = YCurrent + 3
Code "G31 Y" &YNew
While IsMoving()
Wend
YPos1 = GetVar(2001)
Code "G0 Y" &YCurrent
Rem Probe down
YNew = YCurrent - 3
Code "G31 Y" &YNew
While IsMoving()
Wend
YPos2 = GetVar(2001)
YCenter = (YPos1 + YPos2) / 2
Rem move to the center
Code "G0 Y" &YCenter
While IsMoving ()
Wend
Code "G90" 'go back to absolute moves
DoOEMButton (1008) 'zero X axis DRO
DoOEMButton (1009) 'zero Y axis DRO
Code "F" &FeedCurrent 'restore starting feed rate
End If
Else
Rem Probe left
Code "G31 X" &XNew
Wend
Rem Probe right
Code "G31 X" &XNew
While IsMoving()
Wend
Rem Probe up
YNew = YCurrent + 3
Code "G31 Y" &YNew
While IsMoving()
Wend
Rem Probe down
YNew = YCurrent - 3
Code "G31 Y" &YNew
While IsMoving()
Wend
While IsMoving ()
Wend
End If
Tulip6- petit nouveau
Re: Palpage XYZ
Merci Tulip 6
Je vais essayer ce script.
Re: Palpage XYZ
Bonjour à tous !
Heuuu une question bête, comment et où met-on ce script
dans Mach 3 ??
dans Mach 3 ??
Hervé-34- complétement accro
Re: Palpage XYZ
Attention, ce script ne fonctionnera pas avec toutes les cartes d'axe, si c'est une carte Chinoise genre NVEM, BitSensor, XHC ... ça n'ira pas et il faudra le modifier (*) ... de plus il faut changer les valeurs pour des mm, car il est écrit pour des pouces. ( XNew = Xcurrent - 3 'probe 3 inches to left) il faut remplacer le 3 par une valeur de déplacement correcte pour des mm sinon ton palpage s'arrêtera au bout de 3mm de course.
Il faut créer un nouveau bouton pour le palpage de centre, et y "accrocher" le script après. (machscreen)
(*) les cartes Chinoises ne gèrent pas les variables internes de Mach3, donc un Getvar(2000) ne renverra pas la valeur de la position X de contact, mais n'importe quoi de manière totalement aléatoire.
Re: Palpage XYZ
Bonjour à tous !
Bonjour David !
La ST-V2 rentre dans ces cartes "chinoises " qui n'aiment pas ces scripts ?
En fait c'était l'occasion d'amélioration !!
Bonjour David !
Re: Palpage XYZ
Non, la ST-V2 n'est pas une carte d'axe, c'est juste une breakout board, donc le problème ne se pose pas, la BoB ne fait rien, c'est Mach3 qui fait tout le job (et donc c'est tj 100% compatible). C'est ton UC100USB la carte d'axe, et lui il est 100% compatible Mach3, donc pas de problème non plus.
Re: Palpage XYZ
Bonsoir à tous !
Bonsoir David !
Décidément je me tromperai toujours !
donc avec mon UC100USB je peut tenter de faire le script
au dessus ? en modifiant ce que tu as dis ?
A moins que tu aies un autre script qui va bien ??
Bonsoir David !
dh42 a écrit:Salut,
Re: Palpage XYZ
Oui, il faut juste que tu mette une valeur plus grande (30 par exemple) à la place des +3 ou -3 qu'il y a après les instructions YCurrent et XCurrent (c'est la valeur de la distance que fera l'axe pour trouver le bord du trou ; si il ne trouve rien, il s'arrête)
Non, je n'utilise pas de palpeur XY, pour le centre des cercles j'utilise la pinule et le Wizard "Circle Center" de Mach3.
Re: Palpage XYZ
Bonjour à tous !
Bonjour David !
Je comprend ton système avec une pinnule mais il ne faut pas
que le trou soit plus petit que la pinnule !
Autre chose, pour utiliser un script comme ça, (je n'y connait rien à ce sujet !! )
faut-il un palpeur 3D ou un simple palpeur à contact ??
Bonjour David !
Re: Palpage XYZ
Il faut que la palpeur puisse palper en XY, peu importe qu'il soit à contact ou non ou qu'il soit 3D ou pas. Voir l'image du post 1, ce n'est ni un palpeur 3D, ni un palpeur à contact, la base est métallique et la partie que l'on ne vois pas, ça peut être une simple tige métallique (ou une fraise) ... par contre, bien sûr, dans ce cas la pièce à palper doit être métallique, sinon il faut qu'il y ai un contact dans le palpeur.
Re: Palpage XYZ
Bonsoir !
Ok, David moi avoir compris !!
tient ça peut être une réflexion un palpeur 3D
il faut dire qu'il y a plein d'exemple sur le net
mais comment ça se branche ? comme un palpeur
normal ?
normal ?
Re: Palpage XYZ
Hervé-34 a écrit:Bonsoir !
normal ?
Oui, tout à fait, au final c'est tj un simple contact.
Un palpeur 3D fait par Andy (ça date un peu !)
http://www.brusselsprout.org/CNC/1P-Probe/
Re: Palpage XYZ
Bonjour a tous ,
J'ai trouvé un script qui me plait bien sur le net , il permet de trouver le centre d'un carre ( ou un cercle je crois ) en palpant par l'extérieur en XY ( j'ai aussi en interne mais pas encore installé).
Je l'ai installé , il fonctionne bien sur X mais en Y j'ai un ce message " Maximum Travel Reached. Reposition Y Axis Closer To Part And Try Again!" , J'ai essayé de changer les valeurs et de mettre en positif ou negatif de GetVar(2001) >= (VarMaxDistance +15) mais ça ne change rien.
Pour info et malheureusement j'ai une carte HXC sur ma machine , j'aimerais bien en changer ( et par laquelle d'ailleurs ? ) mais j'avoue que j'ai la flemme de recommencer tout le parametrage de ma machine qui fonctionne correctement.
Est ce qu'un grand manitou de Mach3 pourrait m'aider ?
Je joins les deux macro interne et externe
- Fichiers joints
Re: Palpage XYZ
Tu a quoi comme carte d'axe ? (edit: OK, j'avait zappé un bout de ton message ; pas de chance) ... si c'est une Chinoise genre NVEM/NVUM ; XHC ; Bitsensor ... elles ne gèrent pas la fonction GetVar() qui est censée contenir la coord au moment du contact.
Si tu a ce type de carte, essai de remplacer tous les GetVar(2000) par des GetOemDRO(800) et tous les GetVar(2001) par des GetOemDRO(801) de façon à lire la valeur dans la DRO plutôt que dans la variable que la carte ne met pas à jour ; avec un peu de chance ça fonctionnera.
Il y a pas mal de temps, sur Usinages, il y avait une carte dont le palpage ne fonctionnait pas sur un des axes, plus très sûr de ce que c'était ; une XHC USB il me semble ... il y en a même ou le palpage ne fonctionne qu'en Z ...
Je viens de simuler ta macro sur un PC en port // et elle fonctionne en X et Y (avec 20 dans la case "Set Approx. Span")
Re: Palpage XYZ
Bonjour David,
Une fois de plus merci pour tes précieux conseils , je vais essayer ces modifs.
Je te fais un retour après essai.
Re: Palpage XYZ
Bonsoir David ,
J'ai fait un essai rapide ce soir , c'est pas top ...
Faut il remplacer tous les GetVar par des GetOemDRO dans toute la macro ou juste que sur Set Approx. Span ? ( je ne les ai changés que sur Set Approx. Span lors de mon essai ).
Si je ne mets pas le Z a zero avant le palpage ( pour chaque axe ) , le Z ne remonte pas pour se déplacer vers le prochain mouvement ( ça ne le faisait pas avec la macro d'origine ).
Autre chose aussi , lorsque je fais un palpage a zero en Z la broche descends vers la piece après le contact au lieu de remonter , j'avais deja ouvert un sujet pour ça ( tu avais trouvé la solution et ça marchait bien ) mais ça le refait maintenant ( depuis que j'ai installé la macro apparemment ...)
Re: Palpage XYZ
Il faut tous les remplacer (12 occurrences au total)
Vu que je ne connais pas la macro d'origine, je ne peux rien t'en dire, mais il y a bien une ligne qui gère un mouvement en Z en monté et en descente.
Code "G90" &VarLinearMode &"Z" &VarStandOff &VarSafetyRate 'MOVE TO Z STANDOFF
Si on remplace les variables par leur valeurs on obtient la ligne
G90 G0 (ou G1) Z5 F10
le contenu de VarSafetyRate est généré par la ligne: VarSafetyRate = "F" &VarFeedRate * 2 ; c'est ce qui donne le F10 (5*2) VarFeedRate valant 5 dans la définition de la variable en début de programme
et cette ligne
Code "G90" &VarLinearMode &"Z" &VarInitialZ &VarSafetyRate 'MOVE DOWN TO PREVIOUS Z LOCATION
ramène le Z à sa position précédente.
C'est toujours le même problème, ta carte ne gère pas les GetVar(), donc il faut lire la valeur Z dans la visu au lieu de la variable ; dans ce cas il faut remplacer les GetVar(2002) par des GetOemDro(802) dans ta macro de palpage du Z
pour éclaircir les choses, après un palpage, la carte est censée mettre à jour les variables internes Var 2000 à Var 2005 correspondants aux axes X à C, mais comme elle ne le fait pas, on est obligé de récupérer cette valeur dans la DRO (visu) correspondant à l'axe souhaité.
Voila les correspondances Axe, Variable, DRO
Comme les variables 2000 à 2005 ne sont pas mise à jour, elles peuvent contenir n'importe quoi, et donc le résultat peut faire .... n'importe quoi si on tente de les utiliser
et cette ligne
Axe | GetVar() | GetOemDro() |
X | 2000 | 800 |
Y | 2001 | 801 |
Z | 2002 | 802 |
A | 2003 | 803 |
B | 2004 | 804 |
C | 2005 | 805 |
Re: Palpage XYZ
Bonsoir David ,
J'ai finalement réussi a faire fonctionner la macro , en remplaçant les GetVar et en essayant plusieurs combinaisons en G90 G91 j'ai réussi a faire quelque chose qui a l'air de fonctionner.
Encore merci pour ta patience et ton aide
Je ferais demain une video.
Bonne soirée
Bonne soirée
Re: Palpage XYZ
Re: Palpage XYZ
Pour ceux qui chercheraient un palpeur 3D précis et à tarif raisonnable (92€) .... et fourni avec un écran de palpage pour Mach3 et pour LinuxCNc
https://www.usinages.com/threads/palpeur-3d-pour-fraiseuse-avec-interface-mach3.139027/#post-1883368
https://vers.by/en/touch-probes/9-vers-pr.html
Re: Palpage XYZ
Bonsoir à tous !
David, comme je ne sais pas bien lire, tu sais en quel diamètre
est la queue ?
est la queue ?
Re: Palpage XYZ
6mm
https://vers.by/en/blog/user-guide/vers-pr
6mm
Re: Palpage XYZ
Merci !
Re: Palpage XYZ
Salut à tous,
Perso, j'ai trouvé ce modèle il y a quelques mois sur aliexpress pour 63 €.
Queue de 6mm aussi.
Med
Queue de 6mm aussi.
Med
» Palpage Y & Z
» Latence Palpage
» Histoire de palpage...
» Palpage Outil Mach3
» Vérification macro palpage
» Latence Palpage
